profdant139's avatar
profdant139
Explorer II
Nov 25, 2020
Battery failure puzzle: voltage good, little power
I have (or had!) two five year old group 31 NAPA deep cycle marine batteries, rated at 110 amp/hours each. They were not hooked up in parallel or series -- I use one at a time, swapping them out as needed, using solar to keep them topped up whenever possible. (I know that linking the batteries takes advantage of the Peukert effect -- but I like the redundancy of having a completely fresh spare battery in the event of trouble.)
Both of them were as well-maintained as I could manage -- never drawn down below 12.1 volts, always on a Battery Minder Plus at home, never low on water. I even played soothing music for them while in storage. (Not true -- just want to see if you are still reading.). And I check the specific gravity of each cell religiously. (I must admit that battery maintenance is an odd religion.)
They have been great batteries. After 5 years of frequent use, no problems at all, till last week. We were camped in Kings Canyon in cold weather (just above freezing every night). One dark night, we were running the furnace, and the fridge (of course), and the water pump (DW was taking a shower), and some of the LED lights.
Suddenly, the lights started to flicker. The "check" light came on, on the fridge display. The pump got sluggish.
DW quickly finished her shower. I hopped out of the trailer and swapped out the batteries. The new "good" battery read 12.7 volts, and the old "bad" battery read 12.1 volts. Which is not that low. But I knew that it would give me an accurate reading the next morning, after resting.
The next morning, I took a reading on the "bad" battery, and it was at 12.3 volts! How could it have been out of juice?
But wait, there's more. That afternoon, I discovered that the "good" battery, which had been at 12.7 when I swapped them out, was down to 12.1 after a fairly low-load night of use. That is an unusually steep drop. We had no trouble with the battery, but clearly it was on its last legs.
So I finally had to crank up my Honda generator and jam two hours of juice into the "good" battery. (I almost never use my generator, except for routine maintenance.) Since the next day was the last one of the trip, we made it home in good shape.
But here is the mystery: if my "bad" battery was at 12.3 after resting, how come it could not cope with the maximum load due to the furnace and the pump? How could the battery indicate decent voltage while it actually holds very little useful power??
Thanks in advance for your diagnostic wisdom!!
  • The missing number is the "loaded voltage" with the furnace and the water pump both running. 12.1v is the voltage after the "bounce back" after the load is removed.
    12.1v resting is 50% of capacity. Any capacity. 50% of what? is the question. A battery that has aged out will show good voltage until a load is put on it, when it "collapses".
    You could run a little test for that. A voltmeter in the RV would also show that while camping. I like the little ones that stick in a 12v socket, that also have slots for USB charging.
    https://www.amazon.com/Palumma-Charger-Adapter-Display-Battery/dp/B0773BYS6P/ref=sr_1_4?crid=2V53IA1NE1JZX&dchild=1&keywords=voltmeter+12v&qid=1606337825&sprefix=voltmeter%2Caps%2C230&sr=8-4
  • 3_tons's avatar
    3_tons
    Explorer III
    Batteries are likely showing signs of aging (chemical soup sluggishness)...
    Though a bit anecdotal, I recently had a very similar issue on Safe electronic combination keypad with 9v battery - Voltage showed 9.7 but no matter what, safe would not dare open... After a few days of nagging frustrations a competent Locksmith told me that the voltage means nothing, and to simply replace the battery... I did this and safe then opened immediately!
    Best to think of voltage as static characteristic and current as dynamic...
    3 tons
  • 2 things immediately come to mind: age, and temperature. I rarely got more than 4 years out of 6v Trojans, and they would act like yours when failing.
    Cold batteries, if that's the case, don't do well either. Voltage indicates the *potential* to perform, but not the endurance.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
