NinerBikes
Apr 15, 2014Explorer
doughere wrote:
If the slot in the filler tube is mostly exposed ("a little past the bottom of the filler tube"), do nothing; over time it will go down. Watch during charge and if the level starts to cover the slot completely, you'll have to remove a small amount of electrolyte to expose some of the slot to allow the gasses to escape.
Doug
What Doug says. Just don't really ramp up the charging rate on those batteries too much, that will boil the acid up and out. Normal usage or leaving it on a maintenance charger should drop the level, in due time.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
