OnaQuest wrote:
pianotuna wrote:
I would not put my inverter through a shunt. Too much chance of a surge taking out the shunt and leaving me without cabin power. I would have a heavy duty manual switch on the inverter as well.
His inverter is NOT running through a shunt.
The shunt is between his battery negative and ground, just where it needs to be to allow for current measurements.
The OPs inverter
DOES connect through his shunt from his diagram. All current from the - battery post passes through the shunt including the inverter.
Don has different ideas for his setup.
