Hi Rmack1,
You can run your generator forever and the batteries still won't fully charge unless the voltage is increased beyond what a standard converter will provide.
If you are unlucky you may have a WFCO converter, which may rather rarely ever get to "boost mode". That means charging voltage is most probably 13.6.
The solar if it is equipped with a temperature compensation probe on the battery will work in conjunction with the existing converter. Solar will cover the parasitic loads during the day and provide some charging as well.
I do have two temperature compensated methods of charging. Two nights ago when it was 4 c (39 f) the voltage being presented to the battery bank was 15.1. Amps were 78.
BTW I kept my PD 40 amp converter in place so that I have a back up way to charge. It, at least, can be set via the wizard to provide 14.4 volts.
Rmack1 wrote:
1. OK, let me remember. I have a factory converter, I think, that charges my 12 volts when I'm hooked up to shore power or running a gennie. It would probably be impractical to swap it out with a more advanced unit, if indeed I need this. This is a very nice 2013 Rockwood Mini Lite, and it probably has the latest gear.
3. That's interesting, but this happened after running the gennies all day long, till about 20:00 hours, and then we went on the batts. running a 12 volt fan and a furnace, etc.
