pnichols
Dec 29, 2014Explorer II
David,
This is NOT what you asked .... but, but, but you might be ever so slightly interested anyway:
My RV's two paralled 100 amp hour 12 volt deep cycle (by design -> wheelchair batteries) AGM batteries have this month been in our RV for 8 years and one month.
We're getting the rig tuned up for trips this year and I assumed my batteries have to be/must be/gotta be about shot. So ... I load tested them yesterday by using them to only (disconnected from the RV) run a 120V AC 150 watt personal ceramic heater through a PSW inverter for five(5) hours straight. After letting them rest for about an hour I checked their open circuit voltage and it was ~12.31 volts. During the five(5) hour load test, the inline ammeter read around 20 amps, give-or-take, being drawn from the 200 amp hour battery bank made up of these two AGM deep cycle batteries.
I guess they're (happily) far from shot ... thus saving me around $500 for a couple of replacement 12 volt Group 31 AGM batteries ... I had even narrowed my new battery search down to three products in preparation for a disappointing load test.
They've spent most of their 8 years and one month between drycamp spots on the 13.8 volt single-stage converter (floating/charging them) or Ford alternator charging them. All this probably proves that it's not necessarily years or fixed voltage converters that's hard on AGM batteries - it's putting too many cycles on them.
I believe that your OP was looking for, in effect, record-breaking number of cycles field data from users. ;)
