Chris_Bryant
Nov 12, 2015Explorer II
A followup- I bought the HF battery analyzer- it *seems* to be doing a good job, though I need a bad battery to be sure. Tested the 9 Full River DC115-12 batteries, first with the cheapo 100 amp load tester- all tested fine. Then tested with the HF- you hook it up, enter the CCA capacity, it hems and haws for a minute, then gives voltage, resistance, percent of capacity remaining, entered CCA and calculated CCA. Every battery tested out at above rated capacity (770 CCA).
So- looks neat, if it is accurate, it could be handy. On the other hand- the readings could be off simply because these are AGM batteries. The customer said they were not lasting as long as usual, but we've added 12 volt loads, and when I checked, the charging algorithm had been changed to gel, from custom, so the batteries were not being fully charged at all.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
