2Macs's avatar
2Macs
Battery Maintainer for 2 Batteries
I am looking at a Schumacher SC-1200A/CA SpeedCharge 3/6/12 Amp Charger/Maintainer/Tester from Amazon.com to use this winter. Can I use the maintainer on 2 batteries at the same time by connecting them in series?
  • RJsfishin wrote:
    2 batteries, 6 or 12v, is the same as 1 bigger battery when connected in parallel
    If they are 6v, yes, connect them in series to charge/maintain them as 12v
    If they are 12v, they must connect in parallel to charge as 12v.
    This says it all.
    are they 6 volt or 12 volt batteries?
    bumpy
  • I use the Deltran Jr Maintainer to keep the batts happy on the Z Turn and Lawn Tractor thru the winter. Made a jumper to hook the two batts together in parallel.
    It works great. The things crank like new in the spring.
  • 2 batteries, 6 or 12v, is the same as 1 bigger battery when connected in parallel
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
