While gone for an extended time, I plan to keep my car battery charged at home using a Battery Charger Junior. Do I need to disconnect the battery from the auto while charging; or can I charge without...
Battery minders are subject to failure like everything else in this life. I ditto on just disconnecting the battery and it will be fine for 3 if not 6 months left alone. When you leave cables connected, you will have power leak that will drain the battery, eventually killing it.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
