- dsmuirExplorerI have used the https://www.amazon.com/AiLi-Battery-Monitor-Voltmeter-Motorhome/dp/B07CTKYFTG/ref=sr_1_2?crid=2MPJX2W60KGI6&keywords=aili+battery+monitor&qid=1576357649&sprefix=aili+batter%2Caps%2C211&sr=8-2Aili battery monitor as it is cheap and monitors both outgoing and in-going volts and amps along with % of Amp/Hours in batteries. When boondocking it is nice to know what the solar panels are adding to the batteries and seeing what devices are drawing from the batteries.This comes with a shunt that is placed off the negative battery terminal. The deluxe solution is the https://www.amazon.com/Victron-Energy-MONITOR-VTBMV-S-BMV-712-Battery/dp/B075RTSTKS/ref=sr_1_1_sspa?crid=2MPJX2W60KGI6&keywords=aili+battery+monitor&qid=1576357649&sprefix=aili+batter%2Caps%2C211&sr=8-1-spons&psc=1&smid=AERMGYAT5R869&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExN1ZYMzlYM0FOWFhPJmVuY3J5cHRlZElkPUEwMTA5NzQ0MzZXMk43T01PNVNYSyZlbmNyeXB0ZWRBZElkPUEwNzEyNzc3MU4wUjNBNko3UE41SyZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=Victron BMV712 but much more expensive and it has bluetooth so can check many more things with your cell phone.
- VeebyesExplorer III have no life. Had a volt/amp meter as part of the solar system for a boat some time ago. The thing was so sensitive it knew when a thin cloud went by or when the sound system was turned up.
One can never have enough gauges to look at.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
