Gerald55's avatar
Gerald55
Battery monitor pricing
I understand the need for a battery monitor - certainly the analogy of monitoring your fuel level via a fuel pressure gauge strikes home (although it's a little bit off). I want to get one.
What I can't get over is the price. They seem to hover at the $200+ level, and many don't even include the shunt. For things like battery and solar panels, it's pretty easy to understand how the material costs put some floor on the prices, and that once the cheaper manufacturers have come in and gotten close to the floor the prices are pretty reasonable.
As I understand it though, the battery monitory is really just a cheap microcontroller reading the voltage drop across a shunt, and a cheap display + the (fixed cost) programming to do coulomb counting. A few dollars of parts all in all. Where are the vendors coming in to undercut these $200 units?
Often you find the equivalent of battery monitoring technology built into inverters or other electronic devices, at no noticeable impact to the cost. So on top of the above reasoning from first principles, we know for a fact they are added to all sorts of devices at close to zero cost.
Is the market just too small? There aren't enough units sold to bother entering the market? I guess the presence of small niche manufactures like Bogart would help justify that idea.
It seems like it may be an interesting project for someone to develop the some open source battery monitoring software (that's the only "tough" part - i.e., not available off the shelf), and then pretty much anyone could throw together a monitor with a cheap microcontroller (e.g., TI launchpad for $5) and whatever display you want...
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
