NinerBikes
Oct 31, 2014Explorer
smkettner wrote:
I would get solar before the monitor.
I would agree with this. And if you get a little RC charger monitor with an amp meter hooked up in line while charging, with a little practice, your solar panels output capacity versus the voltage and amps the batteries are taking in will give you a really good handle on the State of Charge of your batteries.
If your solar panels are capable of 25 Amps, and your batteries are taking 14.3 -14.4V but only accepting 5 amps or less, you are pretty much topped off on charge on your batteries. The scenario changes a bit as fall and winter approach and the days get shorter, generator time might need to make up a bit early in the day when the batteries state of charge is lowest, then let the solar panel do the top off charging the rest of the sunny day.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
