joelmyer
Oct 31, 2014Explorer
I can't imagine dry camping without something like the Trimetric.
Last winter I collected amp hour usage data to decide how much solar to install. This winter I will use it to manage generator time.
That said, there's 200-300 of us military retirees dry camping for the winter down at Trumbo Point. I'm the only one I know of that has a Trimetric. Most don't even have voltmeters, the ones that do with solar think all is well when they see 12.6+ when the sun has been up a while.
The ones without solar run their generators a lot. In either case when the lights don't work in the morning before generator or sun hours, they go pick up a new battery. That works too I guess.
I guess you could manage reasonably well looking at voltage after sunset and before evening power usage and morning voltage before sunrise and adjusting generator time to make those happy numbers.
I managed a few winters before Trimetric. Start generator when Charge Wizard light went solid on, stop when you could hear generator speed when you turned a light on.
Joel
Joel
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
