BFL13
Nov 01, 2014Explorer II
Trimetric shunt can only go on one battery bank. Doesn't work with a split bank. You can use voltage connection B to read the voltage on another bank but no AH etc. Very frustrating if you want to run split banks so you can fill one while using the other and then switch around.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
