Have two 12v batteries in parallel,is there a way to hook up a meter so I can independently monitor voltages on them. Wanted to use 1 meter with a switch to select Batt 1 or 2 to check.
I was thinking about the Blue sea switch. My reasoning (which could be wrong) I thought by being able to check each voltage separately I could see if one battery was getting weak. Didn't think about having to wait for them to stabilize before checking. I know connected in Parallel voltage same current increases
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
