Have two 12v batteries in parallel,is there a way to hook up a meter so I can independently monitor voltages on them. Wanted to use 1 meter with a switch to select Batt 1 or 2 to check.
Muddling is earned. It is a RIGHT. Younger pretenders need to be admonished.
The OP should fall back five and punt...
Individual AMPERAGE values can be measured and interpolated. Say both batteries are at 50%. Voltage is applied. One battery reads significantly lower amperage starting out but then refuses to taper off anywhere near as much as the first battery.
What is that telling you?
Multiple methods of removing hide from cat...
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
