Shoe2728
Jan 07, 2015Explorer
Battery Monitoring
Have two 12v batteries in parallel,is there a way to hook up a meter so I can independently monitor voltages on them. Wanted to use 1 meter with a switch to select Batt 1 or 2 to check.
Shoe2728 wrote:Yes once the batteries hit the 14.2+ volts run the generator one more hour.
Looks like I do need to get a better converter that will charge batteries faster so generator does have to run so long.
