Have two 12v batteries in parallel,is there a way to hook up a meter so I can independently monitor voltages on them. Wanted to use 1 meter with a switch to select Batt 1 or 2 to check.
Yes PD9200 is excellent. 45 or 60 amp rating is plenty. For best results mount closer to the battery with #4 wire. But generally it will be fine using OEM location and wire.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
