Alc13's avatar
Alc13
Battery on or off
Have been told 2 different things so requesting feedback. Own a 5thwheel. We were initially told that if we are plugged in, we should leave the battery switch ‘off’ ( the switch where the batteries are). If left on, it would wear out the battery ( hooked up so no need for it). We brought it in for warranty work and were told our unit was wired wrong ( they fixed this). When we picked up the battery switch was turned off. Even though the unit was Plugged in, there was not enough juice to get the last slide in ( per the mechanic - he switched the battery on and it worked like a charm). Now we are living in it full time and are wondering if we leave the switch on or off. It is currently on. I just checked the battery sensor and the battery is only at 75% ( usually 100%).
We would do a trial to see if we ‘lose power’ ( if we switch the battery off), but currently in lovely Arizona where it got 119 degrees out yesterday. We have dogs do don’t want to risk things going wrong when at work.
Any feedback would be appreciated. We don’t want to wear out a battery if not necessary!!
Side note: pay the extra money to get temp housing vs staying in a camper here in the summer ??. Lesson well learned!
  • You are going to have to leave the battery switch on. Quite a few of the items in the unit operate off of 12 volt supplied by the battery. Your refrigerator is one of them.Any lights you don't plug into an outlet are also 12 volt. When plugged in the converter charges the battery and may supply a small amount to power other stuff. Any time you use a high draw on the 12 volt side, like running slides in or using your jacks to raise or lower the trailer, you are using the stored energy in the battery.
    If you are not hooked up to electric and you are not using the unit for several days, that is when you would want to turn the battery switch to off. It would prevent parasitic loads from draining your battery. I say this assuming you would not have anything in the refrigerator and would not need it running on gas for that time.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
