MEXICOWANDERER
Jun 04, 2015Explorer
"motor home dying while going down the road "
Is the charging system sitting at a bar, somewhere tossing down a few when this is going on?
You have an intermittent fault at a MAJOR harness junction point OR a low battery plus an intermittently operating alternator (not likely).
Start tracing the positive AND negative battery chassis cables right from the chassis battery. There is a major junction somewhere and it may even be the primary feeder to the vehicle under-dash fuse block.
The intermittent connection junction is passing a lot of current so the bad connection should show signs of major arcing and overheating.
Don't forget the chassis negative ground wiring.
You can proof this point by running a new BRIDGING wire directly from the alternator output stud to battery positive.
A bad connection that cuts power to the ignition - alternator CONTROL circuit would leave the battery dead as a doornail and when you disconnect the jumper battery the engine would die. Not the cause unless you mis stated the symptoms in your post.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
