dpgllg's avatar
dpgllg
Battery Questions
Hello,
First let me say that I know or understand very little of the terms associated with batteries.
We purchased our new 5th wheel last June. Only used it a few times before winter due to illness. The dealer installed this battery:
DEKA MARINE MASTER BATTERY $113.37
SPECIFICATIONS
Cold Cranking Amperage: 650 A
MCA Cranking Amperage: 875 A
Negative Terminal Location: Top Right
Positive Terminal Location: Top Left
Reserve Capacity: 105 min
Terminal Type: Top Mount
Voltage: 12.0 VDC
The battery drained rather quickly while in storage even though the battery disconnect was disconnected. My 5th wheel requires that the passenger side rear slide be out to access the rear of the 5th wheel. I would bring it home charge it using a deep cycle setting and put it back in. his is a chore for me as the battery weighs 49 pounds.
In my old 5th wheel, I put in a Optima Blue Top battery and used it for over 7 years. I let it go on the trade due to its age. I was very happy with the battery, It always had a charge and never died on me.I went online to look for another Optima Blue top and found these three:
Optima Blue Top, Deep Cycle Battery, Group Size 31, 900 CCA $331.99
SPECIFICATIONS
Cold Cranking Amperage: 900 A
Cranking Amperage: 1125 A
Reserve Capacity: 155 min
Voltage: 12.0 VDC
Optima Blue Top, Deep Cycle Battery, Group Size 34, 750 CCA $276.99
SPECIFICATIONS
Cold Cranking Amperage: 750 A
Cranking Amperage: 870 A
Reserve Capacity: 120 min
Voltage: 12.0 VDC
Optima Blue Top, Deep Cycle Battery, Group Size 27, 800 CCA $298.99
SPECIFICATIONS
Cold Cranking Amperage: 800 A
Cranking Amperage: 1000 A
Reserve Capacity: 140 min
Voltage: 12.0 VDC
I have to admit I am somewhat shocked by the prices of the Optima Batteries. On the above batteries I can get a 25% price reduction if I order online through Advance Auto Parts and pick it up in store which is not a problem for me.
Okay so now all of my questions:
1. Does anybody have any experience with the DEKA batteries?
2. If with my very limited knowledge believe I do not need to be concerned with Cranking amps but rather the reserve capicity correct?
3. My 5th wheel has a solar plug jack on the front that allows you to connect a specific 90 watt solar panel to the battery.
Furrion Solar Panel
This Furrion panel costs $499.99. Can I install some type of solar panel to just keep the battery charged while in storage? Do I need a 90 watt panel and if not what size do I need?
4. If I go with an Optima battery which one would work best for me? We do NOT dry camp but we do overnight sometimes in a rest area to get some sleep. We use the lights to get ready for bed. Once in bed no lights are on. The refrigerator is on propane. Once in awhile, we will take quick showers to freshen up. Water heater on propane.
5. I know the battery I have is not even been used a year but I also believe that it could have sat at the dealers for some period of time. Is there any way to determine a manufactor date?
6. Am I crazy thinking about replacing this battery? Is there something else I can do to prevent it from draining so fast? I mean I would go over to the 5th wheel to check on it while stored and put the one slide out and then back in when done. I rarely use the lights. Disconnect the battery using disconnect and leave. I could only do this three times before I needed to charge the battery.
7. Are there other battery options that work as good or better than the Optima batteries for less money?
8. I am concerned that one of these times that the slide will only be partially in or out when the battery dies. If I plug the 5th wheel into my 7 pin connector will this connection provide enough power to get the slide in? Would jumper cables be a better option?
Thanks for reading this long post and I look forward to getting the information I need to make the right choice.
Dave
Having RV issues? Connect with others who have been in your shoes.24,357 PostsLatest Activity: Feb 02, 2026
