FWC
Mar 26, 2021Explorer
As you point out, V is not constant, so you can't us Wh = Ah x V. You need to use Wh = (A x V) x t where t is time.
With a lead acid battery you get noticeably more power from the top 50% of the battery than the bottom 50% as the voltage in the top 50% is about 0.6V higher.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jun 10, 2023
