time2roll
Mar 26, 2021Nomad
You would need some test equipment that would adjust the load to the changing battery voltage and hold amps constant.
Shunts will be rated in amps as a maximum before they heat up and change calibration. They are also rated in mV to match the calibration of the meter. Those mV are the calibrated voltage drop.
Example of shunt rating
