syperk's avatar
syperk
Battery recommendations for 1500W inverter
Does anyone have recommendations for a 12V battery setup that can power a 1500W inverter?
The background: my travel trailer is currently powered by two 6V golf cart batteries (Duracell SLIGC110 215Ah) connected in series. I recently installed a 1500W (3000W peak) pure sine wave inverter with the aim of being able to power my 1.35kW microwave while out in the woods. Unfortunately, when I turn on the microwave, the inverter trips out after a few seconds, and I'm pretty sure it's due to the low voltage protection (which shuts off the inverter when the battery voltage drops to 10.5V).
I've measured the voltage at the battery terminals while running the microwave, and the voltage does indeed drop to 10.5V, so it looks like the battery's internal resistance is just too high to supply the 120A or so that the inverter is drawing with the microwave running. I did an experiment with a smaller 100W load, and the battery voltage dropped by about 0.2V, indicating an internal resistance of approx 0.02 ohms. Is that high for a battery of this type? Does the battery just need replacing? Or do I need a fundamentally different battery setup? Any thoughts welcome!
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
