Salvo's avatar
Salvo
Battery resistance vs. SOC
Bet you've never seen a plot like this before. This a resistance plot of a 200 AH battery charging from 10% SOC to 120%. The three plots are at currents: C/5 (40A), C/10 (20A), and C/20 (10A).
Don't know why, but resistance for C/20 is quite a bit higher than the higher charge rates.
Once past 70 to 80% SOC the resistance really takes off.
Data for these plots was obtained from this plot.
    The effect of the plates heating?
    But then I don't know why then the resistance would decrease past approx. 100%
  • smkettner wrote:
    I would like to see the bottom graph replotted with constant voltage. (vs constant current as shown)
    Then replot the top graph.
    Here ya go. :)
  • I would like to see the bottom graph replotted with constant voltage. (vs constant current as shown)
  • It is interesting that "gassing voltage" also occurs around there. But also you get a lower SOC when using higher amps rate to hit the same Vabs.
    Trimetric manual has a note on charging efficiency at over 80% where they just don't bother to allow for that, it gets too crazy.
