ScottG
Sep 11, 2014Nomad
Check your converter voltage, most likely it's too high.
If all you use your battery for is the electric brakes while towing then it's probably fine for that. If you use it otherwise then it's time to replace it.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
