TLVExplorerSep 08, 2018Battery? Solenoid?Boondocking. Twelve month old batteries are losing charge overnight. The only thing running is the refrigerator (2 way) using propane. Not enough power to turn on generator in the AM. Solenoid is ...Show More
time2rollNomadSep 08, 2018You need to run the generator a minimum three hours with battery voltage at 14.4 to 14.8 volts to get near full charge.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
Related ContentBattery Disconnect Solenoid FuseAG battery switchoverBattery Disconnect SolenoidBattery disconnect solenoidSolenoid as Battery Disconnect?
