Let's start with reality. If you have a camper, some 5th wheels, MH, then you may have a converter and not a true charger.
A converter just converts 115 Vac to 13.5 Vdc. That is all.
A true Battery charger, converts 115 Vac into a 3 stage charger: Bulk, absorptions and float. Without this the your batteries are not being fully charged. If on the other hand you, remove the battery and using a 3 stage charger on the bench, it will last a little longer but not much.
Next depending on how much capacity you have in batteries and you type of 3 stage charger, will determine how long the 115Vac needs to be on.
So, everyone is guessing, until you determine what type of equipment you have installed in your coach.
