RoyB
May 02, 2018Explorer II
I too leave my batteries on the tongue of my POPUP TRAILER sitting inside the Black Plastic cases. Our winter months are not too bad with some snow but temps seem to never get below freezing for over a day. Very seldom water froze over in the creek here close by.
My setup has a master disconnect switch in the POSITIVE side of the batteries which I will turn all batteries off feeding my 12VDC Distribution Panel. There is still two three items connected to 12VDC being the ROOF RAISE motor switch, Breakaway switch, and my BATTERY MONITOR PANEL. The two switches have ON-OFF features which are OFF until activated. My Battery Monitor Panel is monitoring 12VDC direct connected to both Battery Banks and a DC CURRENT meter monitoring the OUTPUT of my Main battery switch. If the MAIN BATTERY SWITCH is selected to OFF then there is no DC CURRENT being measure from the battery banks.
If I notice the BATTERIES starting to drop lower than 12.4-5VDC I will kick in my Shore Power connection for a day or two so from my Garage 20AMP Service connection. I have left my Shore Power connections for the whole period over the winter months if it gets into real cold snap for a couple of weeks. I have a OIL FILLED HEATER that is using one of those THERMOCUBE receptacles (AMAZON) that will turn of if the temperature drops to 35 degrees then stays on until the temp raises to 45 degrees.
Been following this procedure since early 2009 with minimal issues. I do however out of habit mostly do a walk around every couple of weeks and observe the 12V meter reading on my built up BATTERY MONITOR PANEL. I will also feel the batteries for over heated and will occasionally check the fluid levels. Probably do this a couple of times over the winter months unless I see abnormal readings on BATTERY MONITOR PANEL...
Works great for me and as long as the batteries are charged they will NOT freeze.
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
