RidgeRunner24's avatar
Sep 11, 2020
Battery to RV wiring identification
[img][/img]Hi, I'm doing a battery upgrade and moving batteries off tongue of trailer to front storage bay for solar system set up.
Need help identifying a extra 12 gauge wire coming off battery fuse converter tongue connection,daisy chained to another fuse with a 12 gauge wire black/white that disappears under the trailer.
I have a picture, but don't see a way to add to this note.
thanks, Tom
  • Bobbo's avatar
    Bobbo
    Explorer III
    cavie wrote:
    You battery should have a positive wire for the Trailer, A positive wire for the breakaway switch, and a positive wire for the tong (sic) jack. # of ground wires is optional. Can be on the battery or on the frame. It will have at least one.
    And a possible positive wire for the inverter. The wire to my trailer's inverter is actually heavier than the wire to power the rest of the trailer. My battery to trailer is 6g wire. My battery to inverter is 4g wire.
    If your trailer has a solar connector to hook up a portable solar panel, that will also have a (much smaller) wire on the battery's positive pole.
  • You battery should have a positive wire for the Trailer, A positive wire for the breakaway switch, and a positive wire for the tong jack. # of ground wires is optional. Can be on the battery or on the frame. It will have at least one.
    thanks, Tom
  • Bobbo's avatar
    Bobbo
    Explorer III
    On a TT the tongue jack is typically wired directly to the battery too.
  • DrewE's avatar
    DrewE
    Explorer III
    Could go to a few different places: emergency breakaway brake system (though usually that would be unfused), slide motor as mentioned, propane/CO detector, radio preset memory...
    It doesn't seem to me particularly tricky to move/extend the connections without altering the design and needing to figure out what's what. Otherwise, the only real solution is to trace or otherwise sort out what the wire powers, say by disconnecting it from the main battery connections and powering it separately and seeking out what is live.
