jtrantow's avatar
jtrantow
Electrical component identification and wiring help
I needed to replace the water hose on the power reel of my 2006 HR Endeavor. The hose was shot and the mounting bolts securing the reel had pulled out. I replaced the hose, installed reel with bigger bolts, and propped the reel on some foam insulation so that problem is solved.
But, while I had the wet bay panel removed, I noticed the connector to an unknown component behind the wetbay (near the low side latching controller) was broken off at the crimp. This was approx a month ago and I didn't have any crimp terminals. Now I can't find my photo showing which wire went to the connector. Looks like it might be a temperature switch??? with two connectors. The red wire goes to one terminal. Either the blue wire, yellow wire or both go to the other terminal.
***Link Removed***
If someone with a cut down HR/Monaco wet panel could take a look and let me know what you see it would be much appreciated.
