DFord
Oct 31, 2019Explorer
Just use your own water pump. Remove the suction from the storage tank to the pump and then connect a plastic tube to the suction side of the pump. That's all you need. Simple, quick and easy. Your only expense is for a short length of plastic tubing and a barbed fitting to match your pumps suction side. When finished, put the line from the storage tank back on the pump and store the adapter you made for next winter.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
