jefffoxsr's avatar
jefffoxsr
Battery Venting
I have a truck camper. The battery box inside the unit is the standard box with vents in the lid to intake air and a vent on top of the lid with a tube going to the outside of the camper.
My concern is that the air would instead come in the vent tube leading outside and the harmful fumes emitted from the battery charging will exit the openings in the battery cover lid, and as a result we are breathing toxic fumes inside the camper.
The question is why do we assume the fresh air comes in the lid holes and the toxic fumes exit, as desired, out the vent tube that leads outside?
Maybe a mechanical engineer could explain the science of this and how we can be confident the fresh air is coming in the right way and the fumes are actually exiting the unit (instead of the other way around).
Thank you very much.
