pianotuna
Oct 01, 2013Nomad III
Hi Mark,
Are they wired as method #3 on the smart gauge page?
I would separate them and charge each one fully--then retest those voltages. It is a small voltage difference--one cell could be slightly weaker than the others.
If charging separately doesn't do the deed then you might consider a mild equalization or "recovery" process. Have you done an equalization in the last three years?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
