johnm1
Jun 13, 2014Explorer
Battery vs genny questions
Hey all you electrically smarter than me people ... I need some battery help please.
9 days of dry camping. I'm bringing my genny but we're in a State Park, in the middle of 10 families with tents, so I want to run it as little as possible (within reason). Since I don't dry camp all that often I don't want to buy a 2nd battery if I don't need to.
We have a brand new 2015 Laredo 291TG with ...
- WFCO 9875 converter that puts out 14.4 Vdc in bulk mode, 13.6 Vdc in absorption mode and 13.2Vdc in float mode. I talked to WFCO and they couldn't/wouldn't tell me the charging amps (apparently there are too many variables).
- Interstate dual purpose battery (HD24-DP), Group 24 size, 405 CCA, 505 MCA & 100 RC. Not enough space to go to a group 27 without cutting the current welded on brackets.
- 2000 Watt Inverter Generator (Champion). When running, it'll be plugged into the RV shore power cord powering the whole RV.
My battery draw (in amps - checked with DVM in series, not clamp on) is ...
- Only propane detector = 0.18A
- Only fridge (on gas) & detector = 0.60A
- Only main LED cabin lighting & detector = 1.15A
- Only water pump & detector = 8.50A
- Only water heater (while heating) & detector = 0.85A
Best guess useage (for 9 days):
- Fridge and propane detector = 216 hrs.
- Main lighting = 2.3 hrs.
- Water pump = 2.3 hrs.
- Water heater = 4.5 hrs.
If I did the math right, that's about 155 amps.
1 - Can I make it for 9 days with the battery (listed above) and running the genny every once in a while?
2 - How long do I need to run the genny to get a good charge on the battery?
3 - How often do I need to run the genny to keep a good charge?
All in all, I'd rather spend a few extra $$ in gas for the genny than $100 +/- for a 2nd battery that I'll only use for one camping trip per year.
Thanks for your help,
John
John
