johnm1's avatar
johnm1
Battery vs genny questions
Hey all you electrically smarter than me people ... I need some battery help please.
9 days of dry camping. I'm bringing my genny but we're in a State Park, in the middle of 10 families with tents, so I want to run it as little as possible (within reason). Since I don't dry camp all that often I don't want to buy a 2nd battery if I don't need to.
We have a brand new 2015 Laredo 291TG with ...
- WFCO 9875 converter that puts out 14.4 Vdc in bulk mode, 13.6 Vdc in absorption mode and 13.2Vdc in float mode. I talked to WFCO and they couldn't/wouldn't tell me the charging amps (apparently there are too many variables).
- Interstate dual purpose battery (HD24-DP), Group 24 size, 405 CCA, 505 MCA & 100 RC. Not enough space to go to a group 27 without cutting the current welded on brackets.
- 2000 Watt Inverter Generator (Champion). When running, it'll be plugged into the RV shore power cord powering the whole RV.
My battery draw (in amps - checked with DVM in series, not clamp on) is ...
- Only propane detector = 0.18A
- Only fridge (on gas) & detector = 0.60A
- Only main LED cabin lighting & detector = 1.15A
- Only water pump & detector = 8.50A
- Only water heater (while heating) & detector = 0.85A
Best guess useage (for 9 days):
- Fridge and propane detector = 216 hrs.
- Main lighting = 2.3 hrs.
- Water pump = 2.3 hrs.
- Water heater = 4.5 hrs.
If I did the math right, that's about 155 amps.
1 - Can I make it for 9 days with the battery (listed above) and running the genny every once in a while?
2 - How long do I need to run the genny to get a good charge on the battery?
3 - How often do I need to run the genny to keep a good charge?
All in all, I'd rather spend a few extra $$ in gas for the genny than $100 +/- for a 2nd battery that I'll only use for one camping trip per year.
Thanks for your help,
John
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
