BFL13
Oct 25, 2016Explorer II
If you have the two wired so that one has the "load and re-charge" wires on it while the other is "downstream" then that might explain it if the one with the load wires on it is the one losing water more.
That would be from it doing more of the work than the other.
Or it could be just going bad.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
