- swimmer_speExplorer
BurbMan wrote:
Yes, most common size is 5/16-18 threads here in the US. Not sure if Canadian batteries would have metric studs?
I know it's not metric as one has studs that fit a 1/2 inch wrench. - smartyExplorer IIunreal thread
- BurbManExplorer IIIYes, most common size is 5/16-18 threads here in the US. Not sure if Canadian batteries would have metric studs?
- wing_zealotExplorerMine are 5/16"
- buckyExplorer II
swimmer_spe wrote:
toedtoes wrote:
swimmer_spe wrote:
toedtoes wrote:
Then call a shop that carries your battery and ask them what size the terminals are.
Or buy several sizes.
Calling them is not as easy as you think. All calls are only to pick up things, not for inquires.
What battery made and model do you have?
It is an Energizer. Not sure model.
Call the bunny, he'll know. - MEXICOWANDERERExplorerWing nuts are Cheap
Order up 5/16 and 3/8 - toedtoesExplorer IIIWithout more info, no one can tell you what size. Go out and measure the terminal posts.
- Grit_dogNavigator III
mobeewan wrote:
Some are 3/8 inch & some are 7/16. Carry both.
You mean 5/16. - swimmer_speExplorer
It is an Energizer. Not sure model. - toedtoesExplorer III
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
