- FishermanExplorerOn some batteries the positive are 3/8' and the negative are 5/16", others, both are 5/16. I keep a couple of each in the trailer spare parts bin.
- swimmer_speExplorer
red31 wrote:
energizer specs https://www.eastpennmanufacturing.com/wp-content/uploads/Marine-Master-Spec-Sheet-0194.pdf
Thank you - swimmer_speExplorer
wing_zealot wrote:
swimmer_spe wrote:
Right there is your answer, if its 1/2 inch nut/wrench it's a 5/16 inch bolt.BurbMan wrote:
Yes, most common size is 5/16-18 threads here in the US. Not sure if Canadian batteries would have metric studs?
I know it's not metric as one has studs that fit a 1/2 inch wrench.
Thank you. - toedtoesExplorer III
- red31Explorerenergizer specs https://www.eastpennmanufacturing.com/wp-content/uploads/Marine-Master-Spec-Sheet-0194.pdf
- ndrorderExplorer
My batts are threaded 8 mm. Standard wrench size for 8 mm is 13 mm which is almost indistinguishable from a 1/2" wrench. - ndrorderExplorerMy Centennial batteries are 8 mm. FYI
- Grit_dogNavigator IIIBut it could be and could be a 13mm hex, although I don’t believe I’ve ever come across a metric thread battery post.
They’re either 5/16 NC or 3/8 NC. 1/2” and 9/16” wrench respectively. - wing_zealotExplorer
I know it's not metric as one has studs that fit a 1/2 inch wrench. - CA_TravelerExplorer IIISee if someone has an assorment of nuts you can try. Using the one that fits buy the wing nuts.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
