- OFDPOSExplorer
All I could afford wrote:
I'm not an expert and don't claim to be one but looking at this picture makes me think something is very wrong here.
I would love the resident electrical experts opinions
By not reading any info just looking at the drawing/picture...
That's obviously a drawing depicting putting two 6 volt batteries in series to produce 12 volts But I just saw the mess up-- the second wire should be going to the house neg to neg and pos to pos connections....
Carry on ....
https://www.youtube.com/watch?v=BhAX02V20Gk
Well another neat little trick to do , Turn out the lights , get it all dark in the kitchen etc (where the microwave is located) put an old CD in the Microwave and turn it on for 3 seconds , you'll get a nice little lightning show ...
Doh! is this the wrong site for this kind of information :) lol - Good_Sam_Care_TExplorer IITo All,
Thank you all for your time and interest in this thread. Please see below for a correction to the illustration. We do apologize for any confusion with the article.
*****Quick Tips Illustration Correction*****
The cable marked 1+ and 2- in the illustration supporting the “Label
Linking” tip (December 2015 issue) should have a break in the middle.
This cable is used to connect to the motorhome’s 12-volt DC load. The
primary purpose of the illustration is to show the labeling sequence;
connecting cables in the way depicted in the illustration is incorrect
and dangerous.
Thank you,
Mark,
Good Sam Care Team - westendExplorerThe picture may depict two ways of connecting 6V batteries for a 12V system.
Then there were the two guys stealing copper from the substation. One thief got clumsy and they found him frying when the service crew responded to the outage. - azrvingExplorer
Old-Biscuit wrote:
rjxj wrote:
I had too look twice to see if it was a trick. Depending on your goal that could be an excellent set up. First set up a video camera then get quality goggles and a hazmat suit with kevlar. If they get past the molten lead and blinding blue arc as the last connection is made and it did happen to weld in place the ensuing melt down would will make excellent you tube material.
The best I have witnessed was 48 volt 4800 pound fork truck battery 4/0 cables shorting. It's like creating a blue sun and molten copper and lead is blasting out. It's wicked. There are ungodly amps when shorted and they aint taken no for an answer. Something has to give.
I would hate to be the guy that had to make the last cable connection :S
Best melt down I have witnessed was at 2AM when a 220KV Line Disconnect started disintegrating.
Worn spot on end, salt air, started tracking then started arching.
Small bright spot that grew into a very large green eye blinding arch that didn't stop until 15' of cooper disconnect had been consumed.
Gravel underneath was fused together with large pool of melted cooper
Very impressive on a moonless night.
Made for a very busy end of shift with 2 Unit trip---next 5 hrs flew by :B
Wow, that puts me back in Junior territory. :) - 2oldmanExplorer II
I don't, and don't see it available online.
If any of you subscribe to motorhome magazine, check out the December 2015 issue Page 68 to see the actual photo and accompanying article!
As hard as it is for me to believe this is something they would actually publish, I would send them an email or CAll them asap. Somebody's gonna get seriously injured. - 1. IF that picture is REAL, there is NO WAY the batteries had any charge in them
2. IF the batteries had any charge in them, the SPLIT second you connected the LONG cable to either the Neg or Pos post, you would have had a LARGE arc/spark and I doubt you could have proceeded to install the nut on the loose end as the HEAT build up would have burned you way before they caught on fire and melted the Posts and the cases of the batteries. Doug - D_E_BishopExplorerThe most exciting meltdown actually it didn't really melt it welded for a fraction of a second when some non-qual trying to earn his Dolphins disconnected a switch carrying 1500 amps. Resulting ball lightning burned a hole about the size of a softball through the SS cage around the main propulsion motor controls. Finally dissipated through 1" cork insulation to the hull.
Very scary. - wolfe10ExplorerYup, the first interconnect wire puts them in series.
The second one is the one that turns it into an arc welding experiment. - YC_1NomadGuess I have gone brain dead. Nope, I did go brain dead. Looked like two 6 volters in series. I have experienced batteries exploding. Not fun.
- MEXICOWANDERERExplorerI loaned a new 1/2" Snap-On combination wrench to a knothead boat owner. He shorted it from 32 volts positive to a 5/16" hull. Within 2 seconds it went from regular color to bright orange, then melted a coffee cup saucer size hole in the hull. He refused to recompense me for the loss of the wrench. I pulled my tools off the v\boat and left him no wiring schematics, diagrams alternators or coltage regulators which he had not paid for anyway. BE CAREFUL AROUND BATTERIES. THEY EXACT PAYBACK.
