Harvey51
Dec 09, 2014Explorer
Why not just measure the voltage drop across the 15 feet of wire? Divide by 3 to get the drop over each 5 feet of it - and the gain you would get if you cut 5 feet off. While you are measuring check the voltage drop across the connections, which might be greater than in the wires.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
