I want to take the battery out of my TT and connect it to a trickle charger for the winter. Is there any problem with leaving the TT plugged in without a load on the WCO converter?
The WFCO is fine without a load. If the WFCO does fail please replace with a different brand.
Actually the WFCO should drop voltage to 13.2 same as a trickle charger after a few days of non-use. Verify with your voltmeter and save yourself the hassle.
