avarusbrightfyr's avatar
Mar 26, 2020
Converter and Battery Question
Hello all,
I plan on installing an inverter in my travel trailer in the near future, as well as moving my battery from outside the trailer to the front storage compartment to minimize the distance between the battery and inverter, as well as reduce the possibility of theft once I upgrade my battery bank to something more expensive.
My first question is about the ground wire for the battery. It is currently grounded to the frame outside the coach, meaning the positive wire connects to the trailer electrical system, and the ground just dumps to the frame. I'm assuming that if I move the battery inside, I just need to reroute the ground to wire into the storage compartment and to the battery, correct? It doesn't need to be connected to anything else? What about when I eventually install a solar charge controller? Just need to move the negative battery cable to the controller and ground the controller at that point, right?
My second question is about the converter. My electrical panel has a breaker for the converter that allows me to shut it off, and when I do that the 12V system still appears to work just fine. I have the type that plugs into an AC outlet, not one that is wired directly into the panel. I've read online that sometimes removing the converter completely can disable the 12V system, which I suppose means the converter not only charges the battery, but also powers the 12V when plugged into shore power. Is this accurate, or is the 12V side of the panel powered directly by the battery? Is it different for different manufacturers? I'd like to relocate the converter to be next to the battery setup so everything battery related is together, but if I have to run wire through the coach to do it I think I might not bother. My RV came with the "extreme weather" package, so the entire bottom is covered with insulation, and I'm not confident I can run the wire through the floor without hitting obstructions.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
