time2roll
Mar 26, 2020Nomad
avarusbrightfyre wrote:The battery should run the RV with or without a converter. That is until the battery is dead. If you have a charging system direct on the battery you are good to go.
My second question is about the converter. My electrical panel has a breaker for the converter that allows me to shut it off, and when I do that the 12V system still appears to work just fine. I have the type that plugs into an AC outlet, not one that is wired directly into the panel. I've read online that sometimes removing the converter completely can disable the 12V system, which I suppose means the converter not only charges the battery, but also powers the 12V when plugged into shore power. Is this accurate, or is the 12V side of the panel powered directly by the battery? Is it different for different manufacturers? I'd like to relocate the converter to be next to the battery setup so everything battery related is together, but if I have to run wire through the coach to do it I think I might not bother. My RV came with the "extreme weather" package, so the entire bottom is covered with insulation, and I'm not confident I can run the wire through the floor without hitting obstructions.
Thanks!
