theoldwizard1
Mar 26, 2020Explorer II
If you have not bought your inverter yet, buy on that is a combination inverter/charger/transfer switch. Much easier to install and use ! Basically, you remove/bypass your existing converter charger.
Heavy loads (such as your new inverter/charger) should have their positive and negative (ground) connection directly. If there is a ground bus bar inside of your DC fuse panel, you should run a heavy gauge wire from that to the battery negative post.
Small loads (lights, typical 12VDC outlets) can use the frame ground.
