BfLs calculations said that I put 130 ah into a 100 ah battery, I'm curious to what his calculations would be if he calculated your chart.
BFL?
So can you use amps tapering to figure out the soc?
When I was looking at your
chart I noticed that at the
98% soc point your amps had only tapered to 57 amps , I would think that they would be closer to 5 amps or
something considering you were close to
100% soc , idk.
One way I can tell my soc is by
listening to the generator, at first when
the amps are really pumpin you can tell the generator is really working and as the amps taper the generator gets quieter and
quieter and when the generator gets to the lowest noise level the battery is full.
I got rid of the cheap Kisae capacity monitor and replaced it with a Balmer sg200.
I found the Balmer sg200 in the link that BFL posted.
The Balmer is supposed to do everything automatically after I set the
battery chemistry type to (Lifepo4) and then program (tell it I have a 100ah battery)
It's pretty easy to set the Balmer monitor up , the cheap one I never knew if it was set up correctly
I'm trying to figure out how far my amps should of tapered at the point the Balmer reads 100% soc , I'm trying to figure out if the Balmer is giving me the correct soc % reading.
I was thinking when the Balmer reached 100% soc that the amps would be real low like 3 amps.
When my Balmer reached 100%soc my amps were about 40 amps if I recall.
This is Itinerant1 chart I was referring to that maybe BFL will calculate.
It's also the one that shows the amps had tapered to 57 amps at the 98% soc point.
