BFL13 wrote:
Itinerant1 wrote:
I'm at my 99% SOC when it hits absorb.
I presume you know when that is by observing that amps start to taper.
Why do 10 minutes more? 99 is way over 80.
What is the truth about operating under 80%?
Can you do the 20-30 min BB wants past that 99% without overcharging?
What is the "marker" for true full with Li? ( With Wets it is the full SG. With AGMs it is when amps taper to 0.5a/100AH at 14.4v during Absorb.)
When I first started what Iternerant1 said is what I was told too , that's why I used the battery charger that i did , because I was told Li likes to be charged at alot of amps pretty much all of the way to 80%.
Bulk Absorption all of the way to 80% , you don't need the charger to drop down from your set voltage , pretty much 14.4 volts the whole time , no need tor a multi stage smart charger.
If you don't plan to use the battery and your going to store it you keep it around 40 thru 50 % soc would be ideal.
The term float voltage confuses me because I was told you don't float but you take the battery to fully charged, charging at 14.4 volt the whole time until you get there.
Keep in mind I charge with a 2000 watt genset, a 60 amp charger that is fixed voltage of 14.4 volts .
I think when there refering to a float voltage of 13.6 volts I'm thinking there using solar panels and so it drops down to 13.6volt and charges from the sun all day ,
I don't know for sure Itinerant1 could probably tell us.
Doing it my way the Li benefits me because they charge fast , I can get them really high soc quickly and so I don't have to use
generator very long , that means I barely have to listen to it and less fuel usage..
Fuel usage is about 33 cents per hour at current gas station prices.
Run genset about a hour a day to charge.
I don't know much about solar and I don't want to know about it unless I end up buying a house where I could have a bunch of panels.
I heard the benefit you get from Li if your using solar panels is since Li doesn't get damages if you don't get them charged up , so let's say the clouds came out and you had no sun the batteries wouldn't get damaged sitting at 40% soc all the time .
@BFL
Regarding overcharging
My Resister 1 has been snipped.
14.4 volts all the time.
So you read that the Battery management system doesn't protect from over voltage , good to know , thanks.
I assumed that the BMS protected against overcharging but I wasn't sure , I thought that because it seems like the BMS protects from about everything else like cold temp shutdown , low voltage shutdown.
I've always shut the charger off when my monitor reads close to 80%
