CA Traveler wrote:
While the antenna is directional it's not very narrowly directional and doubtful that a limited blind arc has any practical effect once aimed.
I have been frustrated by that, which is why I mention it. With the OEM batwing, you can use the back side of it on the reciprocal for some stations, but with the requirement to point the front exactly at the station, that doesn't work.
I have a Jack on the Winegard mast now, and the Jack has a front side. Same problem with the blind arc. The Wingman yagi sure looks like it would too. Anyway, just my luck to park so the station I want is in the blind arc. Too bad, so sad.
I tried that yagi I posted about that rotates 360 on the Winegard mast, and it did great for that, but it is too fragile to use as an RV permanent roof mounting, so back to the Jack.
