BFL13
Feb 23, 2014Explorer II
It FO3 means the charger is looking at voltage being too high, perhaps it would with a bad clamp or wire connection making R high? So I wonder if a clamp is loose or its wire part broken inside the insulation or whatever, if it would do that? Can you get a voltage across the clamps with the charger on not connected? Don't think I have tried that, so not sure.
EDIT- No joy across clamps. Got FO2 when just on the meter's leads, voltage was 0.6v
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
