westend
Feb 18, 2016Explorer
coolmom42 wrote:Sorry, I have a disconnect on the OP's use and and problems, I guess. Thanks for the correction.westend wrote:
If plugging in devices makes the outlets usable, the first suspect would be a loose wire in the circuit of outlets or a failed outlet. By inserting a male plug, you are establishing the failed continuity of the circuit. When you remove the male plug, continuity is lost.
I think he means the outlets work when he plugs the RV into shore power.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
