Weldon's avatar
Weldon
Bedroom slide not closing complete
Have a 2004 Montana 2955RL and the bedroom slide is not closing all the way. It does close at the top but lacks about 1/2" closing all the way on bottom. Plenty of fluid and the ram does notappear to be leaking
Your thoughts and thanks!
  • Roger I thought about that but have not done so yet. Should be a simple job just don't over do it.
  • There should be a couple of nuts on the end of the ram. You need to adjust the outside one in so it moves the slide farther in.
  • Did not see the glide, bed has rollers on each side at the end.
  • The slide will go back out easily. I have looked but did not see anything out of place. Will look again.
  • Is there a plastic glide under the slide that it is supposed to slide on when moving. It sounds like the glide under the room is missing or is not properly attached. If you can move it back out easily, I'd look under it to see if it is in place.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
